.... trying to get my Kapex to cut absolutely square. There is an elecronic calculator that works out how many degrees you are out. Unforunately, when I tried to use it the answer was always zero. Eventually, I found out that you had to use it in IE and not Chrome and it gave me a result of -0.0121.
So, armed with my rubber mallet I started to make adjustments and then more adjustments and then even more adjustments, until eventually, I had to go to bed with a sore head.
It would be really useful if Festool had a fine adjustment for the Kapex!!
Oh well, I'll try again tomorrow night.
Neil
