It is currently 29 Mar 2024, 15:18
Repairing Grandad's Garden Fork
Re: Repairing Grandad's Garden Fork
Postby RogerS » 04 Nov 2016, 19:03
And according to this table
http://www.sapphireproducts.co.uk/641t1.htm
the setting allowance should be just over 9mm and so 15mm is definitely wrong IMO.
Postby TrimTheKing » 11 Nov 2016, 19:21
When shipbuilding I believe the rivets were thrown up to the guys setting them while still red hot. They then peened them while hot, the cooling process working to pull the two pieces together tighter.
Get your hot gauntlets out Rog! :eusa-think: :lol:
Postby RogerS » 11 Nov 2016, 19:25
Wonder why you need a pein hammer? I'd have thought a flat faced hammer would work just as well.
Postby Robert » 11 Nov 2016, 23:20
More of a spreading action with a ball pein hammer and less likely to split. Plus you can shape it flush easier and the little dents look nicer :)
Postby RogerS » 12 Nov 2016, 09:50
Burned the old wood out quite easily
and removed the rivets. Interestingly I notice that the holes are on a slant. Not sure if this is by design (because of loading on the fork when in use) or just the way it is. Any ideas ?
Marked out the handle on the ash and ripped off the excess. There was a lot of reaction wood inside the ash. Just hope the handle won't go all bendy on me. And was able to align the handle so I could cut out this split/shake
Apologies for the poor focus. I really seem to struggle taking a decent photo with my phone.
Started to plane the square into a circle and then realised that I would probably be better off drawing some reference lines down the length on all four sides.
But I realise that it's going to be a long old haul converting the square cross-ection into a circle and with unsure results to boot. So then I came across this on YouTube which is rather good.
[youtube]M7i73fBljIs[/youtube]
Postby Robert » 12 Nov 2016, 10:11
Hard to tell from the pictures but the misalignment of the holes would happen if the metal bent in use. Sharp radius 'inside' the bend moving the holes relative to the larger radius on the outside. in which case the handle to tines angle was different when it was first made.
Postby Rod » 12 Nov 2016, 13:40
Staggered holes caused by differing radii of the bend?
Neat idea with the BS - I've done it on a smaller scale with my router to make dowels.
Postby Tusses » 12 Nov 2016, 18:09
I think this is the one I refered to earlier ..
https://www.youtube.com/watch?v=B_xxi2TSdTQ
Tusses
Postby RogerS » 14 Nov 2016, 18:03
So I tried the technique in that video.
First try - hard wood dowel
FAIL !
Second try - used a 6mm screw with its head cut off. That too was a FAIL...just snapped off.
Third try - 8mm bolt threaded into the end. That too was a FAIL...it just ripped the thread out.
No idea why they all failed. There was a very loose fit in the guide hole. So I abandoned that and resorted to good old fashioned planing using this guide to check progress.
And that got pretty boring, I have to confess. So I decided to focus on getting the wooden shaft as far in to the metalwork as possible and then worry about the rest of the shaft later.
This is where we are starting from. The original shaft was very nicely tapered into the very end of the metalwork and so I have a long way to go.
The ash remnants inside the metalwork proved excellent at showing the high points that needed removing.
Until finally, I think that this is pretty good.
But now for the :eusa-doh: moment. I'll leave that for the next post.
Postby Rod » 14 Nov 2016, 21:48
I realise it's not the same as making your own but replacement handles are not that expensive
http://bulldoghandtools.co.uk/bulldog-t ... p28sb.html
Postby RogerS » 14 Nov 2016, 23:06
Rod wrote:I realise it's not the same as making your own but replacement handles are not that expensive
That's cheating :D
Previous
Return to General Woodworking
