It is currently 29 Mar 2024, 01:17
Andyp wrote:Rob, if you are watching I would like to do what happens with your Dust Deputy when the PRV is activated. Have you tested? In the time it takes you to switch off the Camvac after the blockage does it manage to suck stuff up through the cyclone?
9fingers wrote:I feel that any significant air leak around the collection bin would defeat the cyclonic separation action and as filter cleaning is such a PITA, I don't feel that inclined to prove this!
Andyp wrote:Am I right in my assumption that a PRV trigger under a HP system is likely to suck up more debris than with LP?
Andyp wrote:Is so then what we need is a PRV that switches off the extractor. Does such a thing exist for a reasonable outlay?
9fingers wrote:Andyp wrote:Am I right in my assumption that a PRV trigger under a HP system is likely to suck up more debris than with LP?
Quite possibly but based on my set up, I don't think there is any need for a PRV in a HVLP system
9fingers][quote="Andyp wrote:Is so then what we need is a PRV that switches off the extractor. Does such a thing exist for a reasonable outlay?
9fingers wrote:What ever sensing method you decide on is not likely to be capable of taking the extractor current so will need to be wired into your relay system via the coil.
Andyp wrote:9fingers wrote:What ever sensing method you decide on is not likely to be capable of taking the extractor current so will need to be wired into your relay system via the coil.
I was afraid of that. Always likely to be a weak point in my plan. (my abilities not the relay itself)
Woodbloke wrote:...whereupon the vacuum almost squashed the barrel flat and ripped off the top of the old dustbin lid separator which I had to re-silicon back in place.
I've since replaced the PRV and it's super sensitive as I only use a tiny 8mm magnet….
TrimTheKing wrote:Woodbloke wrote:...whereupon the vacuum almost squashed the barrel flat and ripped off the top of the old dustbin lid separator which I had to re-silicon back in place.
I bloody told you, TWICE, but no, you had to listen to someone else rather than the man who learned the hard way didn't you!?!
Well maybe that'll learn you, I don't waste my typing fingers for no reason you know…!
Andyp wrote: I tried to use the bandsaw. It is only a small desktop Inca with a 2.5" port. As soon as I switched on the extractor the pressure relief valve blew.
Andyp wrote:Rob,
When you have a moment try slowly closing the only open blast gate. I bet the the PRV will trip before the gate is fully closed.
If my maths are correct reducing 100mm tube down to the 63.5mm on the BS gives a reduction in surface area of well over half.
Woodbloke wrote:Andyp wrote:Rob,
Thanks Andy, that explains it. I'll try your experiment and see if it works - Rob
Edit - not even halfway closed and the PRV tripped - Rob
Andyp wrote:
As I have two of your old machines I would be happy to help out next time you feel the need to upgrade.
