Doug wrote:I was a little surprised to see the maximum blade size on this new model is 19mm...
I've ordered some 12mm DG 4tpi Ax blades to go with it, the machine ought to cut to it's full depth without a really wide blade. Even with the 'so so' 10mm blade fitted by the manufacturers it's still cutting through pretty thick stuff very accurately - Rob
