It is currently 28 Mar 2024, 19:54
Andyp wrote:Gorgeous but imagine coming home half cut and looking at that.
TrimTheKing wrote:I've seen a few in this style and love them! I might see if the boss will allow me to make something like this for when I remodel our utility...
9fingers wrote:Don't forget however quirky the design the hinge pins must be vertical and in line!
Woodbloke wrote:9fingers wrote:Don't forget however quirky the design the hinge pins must be vertical and in line!
They don't need to be vertical but they must be in line, init? - Rob
9fingers wrote:If they ain't vertical the door will tend to self open or self close. It's gravity init.
Woodbloke wrote:9fingers wrote:If they ain't vertical the door will tend to self open or self close. It's gravity init.
Catches or magnets then, init - Rob
Andyp wrote:If doors are surface mounted on the frames then the hinges only need to be parallel.
9fingers wrote:Andyp wrote:If doors are surface mounted on the frames then the hinges only need to be parallel.
Nope, they need to be on a common axis. Try it and see.
Users browsing this forum: Bing [Bot] and 14 guests
