Hi all just out of interest I was wondering if anyone on here knew how much the going rate is to erect a double garage roof (pitched roof over a double garage)?
Also an estimate of how long it should take to erect including all facias and bargeboards.
Just so you know I've already put this roof up but may have others to do. The price was fixed.
The size of the roof 5.7m wide by 7m long (length is gable end side).
Rafters spaced every 600mm (0.6m)
Pitch approximately 30 deg.
Two gable ends with wood ladders made on site for overhanging barge boards (ladders not pre made).
Facia and Barge boards in plastic with soffit all around the building including the gables.
Bracing as usual, node points, diagonals in roof and on ceiling joist.
I'll let you know what the price was set at by the builder after I've had a bit of input.
Cheers Mark
