I have two cyclones in the 'shop now, a little'n and a big Onedia hooked up the the Camvac.
- (170.71 KiB)
- (183.1 KiB)
The suckage on the smaller one is provided by an NVD750 and it will extract your Wisdom teeth if you get close enough
Both are fitted with a PRV which in my experience is essential, especially if the bins are plastic. Without one fitted, a blockage will instantly cause the drum to collapse with undesirable results
...this happened a couple of times on the Onedia.
It doesn't matter if rubbish gets drawn into the dx machine as fine dust gets drawn in as a matter of course. I clean the big cloth filter on the Camvac once a week, especially if I'm been doing some stuff on the drum sander. The crucial thing to do when installing a cyclone is to ensure that everything below it completely air tight; the PRV's are made from a tin lid, an 8mm rare earth magnet and a 4mm bolt with a couple of nuts - Rob
