It is currently 29 Mar 2024, 12:33
RogerS wrote:.......Do you have your Dremel yet ? I have one that you are welcome to try on long term loan........
Coley wrote:Works quite well on brass.......
9fingers wrote:.......If you are mounting the device in some sort of machine/jig etc make sure that the endfloat is minimal.....
Coley wrote:I spent quite a bit of money trying to turn the dremel into a small router. I wish I'd bought the little katsu router before going down that route !! The most useful application I use the dremel for, is cutting with the small discs. I think they're fantastic, they've got me out of a hole many times.
I wonder if the little katsu with a reducing bush might be another option Mike ?
Mike G wrote:9fingers wrote:.......If you are mounting the device in some sort of machine/jig etc make sure that the endfloat is minimal.....
Endfloat? What's that?
Malc2098 wrote:Check out Clas Ohlson for Dremel accessories.
https://www.clasohlson.com/uk/b/Hardware/Tool-accessories
9fingers wrote:Mike G wrote:9fingers wrote:.......If you are mounting the device in some sort of machine/jig etc make sure that the endfloat is minimal.....
End float is the amount by which a shaft can move lengthwise.
Hth
