It is currently 28 Mar 2024, 14:53
Mike G wrote:Oops......edited. Thanks Bob.
So do I have to ask for anything special if I buy flourescent fittings, or are any and all modern fittings now silent?
Mike G wrote:What replacements did you get, Dave, and what do you think of them?
DaveL wrote:Roger, they do give a very white light, I am not into staining very much. I use black for the hats on turned snowman, not much else gets coloured.
RogerS wrote:Trying to match up the colour temperature of the replacement with the others is fun.
RogerS wrote:I also find their light pattern too focussed. Great for spot work, as Rob uses them, but for area lighting duff.
RogerS wrote:Some also cause RF interference on FM and DAB
DaveL wrote:.... I would guess that the interference is caused by a poorly designed switch mode power supply, built to a price, not considering EMC.
RogerS wrote:DaveL wrote:.... I would guess that the interference is caused by a poorly designed switch mode power supply, built to a price, not considering EMC.
Possibly but in my case they are fed from a transformer and so no switch mode PSU. So definitely the LEDs themselves. I did speak to TLC-Direct and they recognised that in some cases it is a problem and so they sent me some 'ferrets' (sic) to go in the leads feeding the LEDs.
Rod wrote:............from TLC.........
RogerS wrote:Definitely a transformer, Bob. When it was put in, switch mode PSU's were not around. No interference when we used 12v halogen lamps. The only thing we have replaced is putting in the LEDs.
Users browsing this forum: Mike G and 14 guests
