Here is a nice bit of free software to plan the layout of a workshop.
You specify the room size, then select the equipment and shuffle it around.
http://www.grizzly.com/workshopplanner#
It is currently 29 Mar 2024, 00:16
TrimTheKing wrote:Great if your room only has 4 straight sides...unless I'm missing an option to shape the walls.
Malc2098 wrote:Nur nur na nur nur!
9fingers wrote:Malc2098 wrote:Nur nur na nur nur!
Did you do the sound effects for the "blues and twos" as well Malc?
Rod wrote:What about the Doppler effect
Phil wrote:Ok, so here is Mike G's workshop, not quite to scale. Phil
StevieB wrote:Phil wrote:Ok, so here is Mike G's workshop, not quite to scale. Phil
Are you sure - its got a lathe in it
Malc2098 wrote:I can do odd shapes.
Phil wrote:A layout by someone else.
http://cdn0.grizzly.com/shopplanner/v1- ... a0222bdf6fMalc2098 wrote:I can do odd shapes.
Indeed, I shall be having a play. I have also got it set up in Sketchup so might just stick with that as it gives me the 3D view too.
Nice one Malc.
That should sort Trim out with his layout.
