It is currently 29 Mar 2024, 03:17
Joining cills
Joining cills
Postby RogerS » 04 Jun 2018, 07:33
Mulling over how best to joint some long lengths of cill to minimise the inevitable shrinkage and subsequent water ingress.
(14.62 KiB)
A - simplest. Butt joint. Worst from water ingress. No resistance against lateral movement
B - better. Screws can go through to hold the joint. No resistance against lateral movement
C - best. Screws can go through to hold the joint. Resistance against lateral movement
Welcome to hear people's thoughts
Re: Joining cills
Postby Andyp » 04 Jun 2018, 08:39
A wedged scarf perhaps?
I have a scarf joint to do soon but I will be sticking to KISS and doing a half lap.
Re: Joining cills
Postby RogerS » 04 Jun 2018, 12:23
Elegant, Andy
Re: Joining cills
Postby Rod » 04 Jun 2018, 15:23
Can’t you get the timber long enough to avoid joining?
Re: Joining cills
Postby RogerS » 04 Jun 2018, 16:16
Rod wrote:Can’t you get the timber long enough to avoid joining?
8m ? I don't think so ! :D
Re: Joining cills
Postby 9fingers » 04 Jun 2018, 17:43
OK so a joint is unavoidable.
I'd go for a timber that is fundamentally rot proof so Iroko for hard wood say or accoya if you are painting.
Dilute., warmed epoxy soaked into the ends. Alignment dowels and a worktop clamp to winch them together with more epoxy. When dry pot the clamp recess in epoxy & filler to keep water out of that.
Or there is always upvc :lol:
Re: Joining cills
Postby Rod » 04 Jun 2018, 18:48
Is this for The Orangery?
Re: Joining cills
Postby MJ80 » 05 Jun 2018, 08:29
When I used to do really long cills for sliding doors this is how I did it.
I would do a really long shallow mitre and on the bottom face route in a plywood cleat covering about double the length of the joint and get some screws in through that.
MJ80
Re: Joining cills
Postby RogerS » 05 Jun 2018, 11:00
Thanks everyone. Yes, it is for the Orangerie. Just had a price for Accoya :o (£600) It'll be softwood and painted !
Return to General Woodworking
cron
