It is currently 28 Mar 2024, 17:34
Malc2098 wrote:Howdens have given me a cash account in the past. It might be worth calling on your local outlet.
Rod wrote:I replaced all our flat panelled sapele doors with solid pine raised panel doors many years ago.
I cheated a bit by laying the old doors on top of the new ones and pencilled round the shape.
RogerM wrote:10 doors hung and 5 to go. So far I'm very happy with them. Construction is a chipboard core with a 35mm lip on each side and top and bottom, leaving plenty of room for trimming to size. The veneers are mainly book matched which is a nice touch, and the thickness of the lipping means that there is always plenty of "real wood" to screw into for hinge attachment etc. The grooves between the veneered panels are cut into solid oak strips set in to the core, so there is no hint of a composite material on the outside of the door. I've lightly cleaned up each one with my ROS, degreased with a wipe of meths and then given 2 coats of Osmo door oil. Total cost is £150 per door including all door furniture and 3 ball bearing hinges per door.
This is the first time I've fitted composite doors so I have nothing to compare them with, but I would use again. Deanta Doors Ely for the solid doors, and Deanta Kerry for the glazed ones, bought through"Doors of Distinction" in Sidmouth, who undercut their own website prices.
usall wrote:RogerM wrote:10 doors hung and 5 to go. So far I'm very happy with them. Construction is a chipboard core with a 35mm lip on each side and top and bottom, leaving plenty of room for trimming to size. The veneers are mainly book matched which is a nice touch, and the thickness of the lipping means that there is always plenty of "real wood" to screw into for hinge attachment etc. The grooves between the veneered panels are cut into solid oak strips set in to the core, so there is no hint of a composite material on the outside of the door. I've lightly cleaned up each one with my ROS, degreased with a wipe of meths and then given 2 coats of Osmo door oil. Total cost is £150 per door including all door furniture and 3 ball bearing hinges per door.
Hi Roger, we're coming in a little late on this conversation but hope you can help. Four plus years later, what is your opinion on the Deanta doors? Would love to hear a review. Thank you.
