It is currently 28 Mar 2024, 22:16
by Rod » 06 Aug 2018, 11:26
A perfectly nice looking piece of cherry until I planed the surface off??
It was this piece on the right:
- Old Oak
- Name:
by Malc2098 » 06 Aug 2018, 11:28
Lodgers! You should be charging rent!
- Sequoia
- Name: Malcolm
by 9fingers » 06 Aug 2018, 12:27
I had that in a batch of American Ash. Channels about 3mm diameter in one board. I managed to cut round it as it turned up in the early stages of conversion from rough sawn to usable stock.
- Petrified Pine
- Location: Romsey Hampshire between Southampton and the New Forest
- Name: Bob
by RogerS » 06 Aug 2018, 15:55
Cor, that's going to take a lot of grain filler
- Petrified Pine
- Name:
by Phil » 12 Aug 2018, 15:08
Malc2098 wrote:Lodgers! You should be charging rent!
It is an 'unplanned' feature in the timber.
- Old Oak
- Name: Phil
Return to General Woodworking
