I've been making some picture frames to show some prints ready mounted on light card behind glass.
I'm using some medium quality hardboard ( not oil tempered stuff) in the back of the frames.
The largest is about 550 x 440 mm and I wondered about treating the hardboard to keep it flat. Usually one would seal both faces but I wondered about leaving the surface that faces the back of the picture bare so that it there was any movement, it would act to press the picture towards the glass.
Assuming the textured surface would be more absorbent to moisture, I could put that facing inwards bare and seal the visible smooth face with some thin varnish or similar.
Anyone tried this method to exploit assymetric treatment of the board warping to order? Do you think this would be a good plan?
TIA
