It is currently 29 Mar 2024, 11:23
Andyp wrote:Is 2.5mm too small to cut off with a jigsaw, freehand?
Woodster wrote:I have a large square that could be used (with some ply) for the L & R cuts as I can clamp it to the work top at the front edge. If I can take 5mm off the back cut that should be straightforward if the wall is reasonably square.
Woodster wrote:I can’t seem to find my Elu Router at the moment but I did buy a Katsu last year for use on my lathe and found this in the box. Never used anything like it before. I think it’s designed for curves but could it be used?
