After the planer thicknesser event which I was somewhat underwhelmed by, glad to see the Basingstole branch of Axminster upping their game by calling in expert support. I'll be doing my best to get along their on Sunday.
https://www.facebook.com/events/716997291708828
"There are many ways to produce this classic joint, from the use of a chisel and mallet to a dedicated morticing machine. One way is to use a router which produces a super accurate mortice, but It has usually always involved the use of a 'shop made' jig. Watch Rob Stoakley not only produce a mortice, using just a router, a few assorted hand tools, some cramps and bits of plywood for packing, but also a wedged, exposed and rounded tenon to fit in it!
If you want to see how to produce a classy variation on the standard joint, which will undoubtedly add a little 'je ne sais quoi' to your projects, this is a demonstration you simply can't afford to miss."
