It is currently 28 Mar 2024, 15:21
Dr.Al wrote:...... I like the close increments as I can work gradually down to the right size and not take too much off per pass.......
PAC1 wrote:22mm! What will you use to force a bit of hardwood through that! And what will you use to sit the plate on as you hit it...
Mike G wrote:PAC1 wrote:22mm! What will you use to force a bit of hardwood through that! And what will you use to sit the plate on as you hit it...
Oak pegs for green oak framing, and I'll use a lump hammer with the plate sitting over a dog hole in my bench. My final size will be 20 or 18. The 22 is just to start them off from square.
Mike G wrote:I've got a number of those set up for various different sizes. I made my curtain poles like that a few months ago. I've also got a jig set up for the router table. However, even if it is just to produce blanks for one of the other methods, I want a dowel plate for these sorts of sizes. I know it works for these sizes, because I've seen people do it.
novocaine wrote:The skills have gone for making them these days. But so have the vampires so its not all bad.
Mike G wrote:novocaine wrote:The skills have gone for making them these days. But so have the vampires so its not all bad.
Coincidence? I think not.....
Dr.Al wrote:Mike G wrote:PAC1 wrote:22mm! What will you use to force a bit of hardwood through that! And what will you use to sit the plate on as you hit it...
At that size I'd be tempted to make a chisel based one like this:
AndyT wrote:Mike, I've remembered that there's another method of cutting pegs which I have seen demonstrated which might be better for your 22mm requirements. It uses a sharpened steel tube and is quick and efficient. Here's a very detailed video about it.
https://youtu.be/uV2wW9Y8-bc
Mike G wrote:For those interested in having a dowel plate, this is what I am proposing. Please feel free to comment if you want it a bit different. This is a big old lump of steel, and I've spread out the holes so that it hopefully doesn't develop any dishing from being bashed.
