Hot off the press
http://www.hse.gov.uk/pubns/priced/l114.pdf
It is currently 28 Mar 2024, 13:07
Loghead wrote:I'm going to buy a table-saw from the USA and a dado set to go with it.
If you obey those safety rules completely, you would only ever use your table-saw for ripping and at a stretch cross-cutting. (And maybe panel reducing.) I suppose ripping is all the saw was really designed for, but with care you can cut joints on the TS; for which you must remove the guard of course!
Hey HO!
Newbie_Neil wrote:Loghead wrote:I'm going to buy a table-saw from the USA and a dado set to go with it.
Why bother with using a tablesaw, when it is much quicker and FAR SAFER to use a router than a dado blade in a saw.
9fingers wrote:Newbie_Neil wrote:Loghead wrote:I'm going to buy a table-saw from the USA and a dado set to go with it.
Moderator note: DADO wars are not allowed here
