It is currently 28 Mar 2024, 21:17
TrimTheKing wrote:I don't know what TS you have Phil but mine was simple to set up (when you know how) and if I bump into it the only thing I have to worry about is how bad the bruise will be...
I can kick mine and not rattle anything on top of it, it's rock solid.
RogerS wrote:Nope...can't answer that. Today I used the Festool TS55 to rip down a very long heavy awkward board. It would never have gone on the table saw and not enough throat on the bandsaw.
I cut some boards to the right length easily and simply using my accurate but cheap Bosch mitre saw. (90 degrees - bang on and no slop, David!!
I needed to trim 5mm off a pre-glued moulding and used the bandsaw for that (the big one) and the a short while later, trim a smaller bit off a smaller moulding and used the baby bandsaw.
Then I needed to rip a few floorboards down and used the table saw. Much easier, quicker and better supported than using the big bandsaw.
chataigner wrote:Just a thought, but the key weakness of a bandsaw - that it doesnt cut truly straight, can be overcome by using it to cut a tad oversize, then correcting the edge with a router guided by a straight edge.
firedfromthecircus wrote:The next stumbling blocks after lack of knowledge and skill are lack of space and lack of money. (it's all tied up in bicycles!) I had a quick look on a popular auction site at 2nd hand Startrite and Wadkin tablesaws.
