It is currently 22 Mar 2019, 23:45
Spoked Wheel Jig
Spoked Wheel Jig
Postby Dalboy » 17 Oct 2015, 20:32
I make toys as well as spending my time turning. One of the things that I need are spoked wheels of different sizes some of which I can do on the lathe. Well this jig makes setting up to drill holes in the centre hub a lot easier and less time consuming.
Blank ready for attaching
How the blank is mounted
Mounted and ready to drill
The end result with a rubbish piece of wood still a happy result this took less than 5 minutes from cutting the blank to all the holes drilled
Dalboy
Re: Spoked Wheel Jig
Postby Rod » 17 Oct 2015, 21:17
You've made a Dividing Head
This is my electric one I made:
Postby Wizard9999 » 17 Oct 2015, 22:29
You chaps are all too clever for me :lol: .
Terry.
Wizard9999
Postby Dalboy » 18 Oct 2015, 00:06
Rod wrote:You've made a Dividing Head
Smart bit of kit that one Rod
Yep but did it only cost you £2.99 :lol: :lol: :lol:
Dalboy
Postby Andyp » 18 Oct 2015, 08:09
What's the next step Derek? Bandsaw so only the "holes" are left?
Postby chataigner » 18 Oct 2015, 09:33
:text-bravo: I like the 2.99 version : more pennies left for malt scotch.
Cheers !
http://www.rue-darnet.fr
chataigner
Postby Rob » 18 Oct 2015, 09:36
Very ingenious Derek....a vertical indexing system
Rob
Postby Rod » 18 Oct 2015, 09:48
Sadly no - about £60 ( the case at £20 was the most expensive part ) proprietary ones cost £400!
I used to use this:
Postby Dalboy » 24 Oct 2015, 20:26
Well the first set of spoked wheels have come off the jib all the centres are nicely in the centre but does not show in the picture. The wife liked the 8 spoked version so made them.
The first one was a 12 spoke wheel with the parts
The 4 wheels together
This shows the back of the wheel
Dalboy
Postby Commander » 26 Oct 2015, 11:23
Very nice!
Commander
Postby Phil » 30 Oct 2015, 16:47
Now that is really a neat idea. :D :text-goodpost: :text-coolphotos: :text-+1:
Derek, what did you make the metal indexing wheel from? And how did you space the holes?
Postby Dalboy » 30 Oct 2015, 18:50
Phil wrote:Now that is really a neat idea. :D :text-goodpost: :text-coolphotos: :text-+1:
The disc is cut from a piece of 1/8" thick steel plate and marked out (Take your time here) before drilling, I drilled the centre hole first then placed it on a pin under the drill press then drilled all of the holes. To get it round I used the centre hole again and rotated it against the grinding wheel making sure not to overheat it. It takes a bit of time but worth it in the end. The indexing pin is made from brass and threaded rod and is spring loaded with a little turned handle on the back.
This is the originator of the jig HERE hope you can see it as you may need to sign up
Dalboy
Return to Tips & Tutorials
