It is currently 28 Mar 2024, 15:49
Tweaking mortices tip
Postby RogerS » 23 Aug 2018, 11:53
If you need to adjust the size of a mortice then the temptation is to simply have a go with a chisel. If you're like me, the end result is never 90 degrees to the face.
But clamping a pice of scrap as a guide like so
means you have a nice flat support for your chisel.
I find that gently paring away in an arc and little by little is the best way to trim the mortice as opposed to a full-frontal assault. Skew chisels make this a doddle.
Re: Tweaking mortices tip
Postby Malc2098 » 23 Aug 2018, 12:01
Elegant!
:text-goodpost:
Postby RogerS » 23 Aug 2018, 12:12
Thanks Malcolm.
I meant to add that if what I posted wasn't clear then I could have a go at posting a video of it.
Although not sure in which year :lol:
Postby 9fingers » 23 Aug 2018, 12:19
RogerS wrote:Thanks Malcolm.
Good Tip Roger. :eusa-clap:
My usual point of adjustment is the tenon.
Postby RogerS » 23 Aug 2018, 12:27
You can apply the same tip to a tenon
Return to Tips & Tutorials
