It is currently 24 May 2018, 05:25
Old file
Old file
Postby Wizard9999 » 07 Oct 2016, 21:54
I'm in the process of having a bit of a clear out at the moment. I came across a big old file today, easy enough to put a new handle on it but it is also quite rusty, not crazy caked in the stuff but rusty all the same. Obviously I can't do a Wallace and grind the heck out of it and make it shiney, not if I want to use it as a file anyway, but is there any sensible way to bring it back to life?
Terry.
Wizard9999
Re: Old file
Postby Robert » 07 Oct 2016, 22:46
The easiest option is to just buff it with a wire brush. it doesn't have to look pretty to work.
I'd check it is still sharp though by actually filing something with it. if someone has filed away at something hardened it could be burred up and useless.
Re: Old file
Postby 9fingers » 07 Oct 2016, 22:51
You can also do the electrolytic de-rust process after wire brushing.
The rust will possibly have pitted the cutting edges but it might still work. Otherwise save it as a base to grind up a special lathe tool for some job in the future.
Re: Old file
Postby Wizard9999 » 07 Oct 2016, 23:19
Thanks both, I'll give it a go with wire brush and see how it works after that before spending too much ime on it.
Terry.
Wizard9999
Re: Old file
Postby Wizard9999 » 08 Oct 2016, 10:58
I saw a couple of online references to using various acids to clean files, they even suggested that using them will re sharpen the file (not sure I understand how). But the idea of using acid that every says you have to wear a hazmat suit to touch does not appeal. I have also seen reference to using diluted (50%) distilled vinegar to remove rust, so was thinking about giving that a go.
Anyone got any experience of using diluted distilled vinegar to remove rust?
Terry.
Wizard9999
Re: Old file
Postby Dan0741 » 08 Oct 2016, 17:01
Terry I bought an old school issue set square from a reclaim yard recently and used the vinegar trick - worked brilliantly. Clearly wont resolve rust pitting but not too important on a file. Make sure all is submerged and then wait for 48 hrs, then wire brush and do it again until clean and rust free. Prob 2 dunkings required. I use the clear stuff from tesco. Use rubber gloves and do it in the open air. ;)
PS I didnt dilute, Im guessing it comes diluted to a certain degree?
Dan0741
Re: Old file
Postby 9fingers » 08 Oct 2016, 20:24
Culinary Acetic acid AKA white vinegar is usually sold at 6% concentration.
Re: Old file
Postby Commander » 26 Nov 2016, 16:43
Any idea if the vinegar trick would work on my newly rusted hand plains?
Commander
Re: Old file
Postby Tusses » 26 Nov 2016, 16:49
Commander wrote:Any idea if the vinegar trick would work on my newly rusted hand plains?
try it ?
I like Jelonite as something to keep in the shop. Don't know if you can get it there ?
I've always wanted to try the electrolytic process too .. just never got round to trying it.
You just need a bucket, and a car battery charger .
Tusses
Re: Old file
Postby Wizard9999 » 26 Nov 2016, 18:35
I can't see why not, it worked a treat on a whole bunch of old files I found. Need to get around to getting a few new handles now.
Terry.
Wizard9999
Re: Old file
Postby Rod » 26 Nov 2016, 21:32
Jenolite's main ingredient is Phosphoric Acid which is the main ingredient of Milkstone Remover.
Much cheaper and readily available from Agricultural Suppliers. 5lts for about £15.
Re: Old file
Postby Tusses » 26 Nov 2016, 23:32
Rod wrote:Jenolite's main ingredient is Phosphoric Acid which is the main ingredient of Milkstone Remover.
Filed in the grey cell data bank ! .. Thanks Rod
Tusses
Re: Old file
Postby Commander » 29 Nov 2016, 05:39
Thanks guys! I will see what I can get my hands on over here and give it a try! :D
Commander
Re: Old file
Postby Tusses » 29 Nov 2016, 12:19
most "Cola" .. yes coca cola .. has phosphoric acid in it.
it's a very weak solution, but people do use it to clean rust/chrome bumpers/jewelery etc.
use full strength .. not the diet stuf ! :D
Tusses
Re: Old file
Postby Rod » 29 Nov 2016, 13:05
The Milkstone Remover is used (diluted) by the diary industry to remove scale etc from the milk pumping machines, pipe lines, tankers etc.
Return to Hand Toolery
