It is currently 28 Mar 2024, 17:05
9fingers wrote:1/4" x 20 tpi comes in two flavours American (unified thread) and British (Whitworth thread)
Maybe try 1/4" Whitworth or BSW in your search rather than the TPI
I should be readily available but I'm about to go and have a look on your behalf.
I'll report back
chataigner wrote:Thanks Bob, just to be sure, can you confirm that the whitw and UNF are mutually compatible ? If so, as you say, the whitw is the best choice. I didnt realise they could be interchanged.
9fingers wrote:chataigner wrote:Thanks Bob, just to be sure, can you confirm that the whitw and UNF are mutually compatible ? If so, as you say, the whitw is the best choice. I didnt realise they could be interchanged.
They are not exactly the same but unless you have a precision application and both the nut and studding are precision made you are not likely to notice a difference. If push comes to shove then run a tap through the offending item.
The US one will be 1/4" UNC not UNF and should still be readily available. Do you know the spec of what you actually need? I'm guessing it could be for the veritas clamps in which case it is possibly UNC.
