It is currently 19 Jun 2018, 21:08
Cutting Brass sheet
Cutting Brass sheet
Postby DaveL » 05 Feb 2016, 15:49
As some of you will know, I am a clog wearer. The front of my clogs have a "toe tin" which protects the wood and the leather from being abraded, particularly if I kneel down, searching for things I have dropped in the the space time warp called a workshop floor.
This is a clog, named after me that is my first choice of footwear, see my clog maker here.
While they are called a tin they are made of sheet brass, about 0.5mm thick. They are in short supply as the wearing of clogs is not what it use to be, so I thought I might have a go at producing a few. I figured that it would be a nice job for a small CNC machine and a quick look on eBay found this:
Here is the listing, it does not list metal as a material it can machine, but I cannot think of reason why it should not work, can any of you?
I thought once I had the machine it could also be used to machine wood, adding names or inlays on boxes, but the first use would be cutting toe tins.
Regards,
DaveL
Re: Cutting Brass sheet
Postby Robert » 05 Feb 2016, 16:05
The only way I could see it working is if you glue the brass to some wood before attempting to cut it. problem comes at the end of the cut when there is nothing to hold the workpiece - it will probably fly away and/or be gouged by the tool and bent.
I do like the toy you have found though so do get one and show us what it can do :)
edit. just looked on youtube and there are a few reviews plus lots of comments on quality that seem a bit mixed. might still be worth it for entertainment value..
For the pieces you want I'd just cut them out with some decent tin snips, dress it flat with a hammer then form the curve and finally polish it with a mop on a bench polisher/grinder.
Postby DaveL » 05 Feb 2016, 16:21
This is what a new a one looks like
I was going to drill the holes ans screw it done before cutting the outline.
Regards,
DaveL
Cutting Brass sheet
Postby Rod » 05 Feb 2016, 18:42
It says it can cut metals with a spiral bit.
I normally use my Hegner to cut brass but that machine looks more fun?
Ps are you called Forest or Dean ?
Postby Sheik Mabouti » 05 Feb 2016, 19:26
Dave,
I don't think a 200w spindle would be man enough to cut brass, I would suggest trying to find someone that has a waterjet.
Sheiky
Sheik Mabouti
Postby TrimTheKing » 05 Feb 2016, 19:36
And you Sir win today's best forum name competition!!! :eusa-clap: :obscene-drinkingcheers:
:text-bravo:
Welcome aboard, and the approval thing will disappear when you've made 3 posts.
Postby Sheik Mabouti » 05 Feb 2016, 19:51
Thank you Mark, do I get the competition prize before my three posts :lol:
Sheik Mabouti
Postby Andyp » 05 Feb 2016, 20:32
Brilliant monica and welcome to the forum :D
Postby Sheik Mabouti » 05 Feb 2016, 21:58
Thank you for the welcome
Sheik Mabouti
Postby TrimTheKing » 09 Feb 2016, 09:22
Andyp wrote:Brilliant monica and welcome to the forum :D
Why you calling him Monica?
Postby 9fingers » 09 Feb 2016, 09:59
If you are not a lunnon boy you would not understand Mark :text-lol:
Postby Robert » 09 Feb 2016, 10:39
I'd have spelt it Moniker as in what's your name....
had to check 'spelled' or 'spelt' though - seems either is right.
Postby Sheik Mabouti » 09 Feb 2016, 15:36
Ok, ok
What happened to the Brass sheet ?
Yours
Monica Mabouti
Sheik Mabouti
Postby TrimTheKing » 09 Feb 2016, 18:08
Postby DaveL » 09 Feb 2016, 21:40
Well to get back to the brass sheet, I have now a nice new square of 24swg, it was delivered today. I had not thought about cutting it with the scroll saw, what blade would you use?
I have decided not to buy the cnc that I linked to in the first post, but I am thinking about one with a water cooled 800 watt spindle, it's a bit more expensive but it looks much more useful.
Welcome to the forum Monica.
Regards,
DaveL
Postby Sheik Mabouti » 09 Feb 2016, 22:00
Dave,
Monica says thank you for the welcome :lol:
That sounds better, but you must be aware that spindle bearings are not designed for drilling even in
wood base materials , for that reason I machine with a spindle (4hp) and have a drill head for holes.
You can ramp spiral drill the holes, but the size of holes on the brass you have would be slow with the
size of cutter you would use.
Sheiky
Sheik Mabouti
Cutting Brass sheet
Postby Rod » 09 Feb 2016, 23:42
Dave I use metal cutting blades
I have a set of various types from Hegner which include metal cutting ones but I also bought a batch from Mike in the USA (Flying Dutchman ones).
He used to sell different types for different metals.
Workshop Heaven sell Pegasus ones:
http://www.workshopheaven.com/tools/Peg ... lades.html
Postby Andyp » 10 Feb 2016, 17:01
I didn't hence the lower case m. Moniker is the correct spelling, I was trying to be funny.
9fingers wrote:If you are not a lunnon boy you would not understand Mark :text-lol:
Robert wrote:I'd have spelt it Moniker as in what's your name....
At least the Bobs and Robs understood.
Postby 9fingers » 10 Feb 2016, 17:37
Terrible when you have to explain humour isn't it? :lol:
Many google references would have you believe that the original of the slang for name is linked to Monica James, the Australian author but just because the interweb says so, don't make it correct.
I feel the both one the grounds of her being too young and the plural nature of her name James whereas it should stricly be "Jame" to rhyme with "name" if indeed the origin is from rhyming slang.
Digging a bit deeper suggests it has been in use as slang for a name (or perhaps signature) since the mid 19th Century and might originate from tramps slang but there my sources dry up.
The expression I'm used to is "Put your monika on that" being a request for a signature rather than simply a reference to a name. In this context Monika could be thought of as a corruption of Monarch or someone in authority who could provide an authorising signature or seal on a document.
Postby Rod » 10 Feb 2016, 17:43
I understood but then I had no idea how it was spelt as I'd mainly heard it spoken
Postby DaveL » 19 Feb 2016, 15:34
Well I found some fine blades in the box of scroll saw bits and had a go.
It will match the other one after a few months of knocking against things.
Regards,
DaveL
Postby Rod » 19 Feb 2016, 18:37
Nice work
Do you ever get picked up by the police for wearing dangerous weapons?
Postby DaveL » 20 Feb 2016, 01:04
Rod wrote:Nice work
Not so far. I do try not to clog anyone but do recall a student complaining I was stood on his foot.
Regards,
DaveL
Cutting Brass sheet
Postby TrimTheKing » 09 Mar 2016, 17:54
Andyp wrote:I didn't hence the lower case m. Moniker is the correct spelling, I was trying to be funny.
Andyp wrote:At least the Bobs and Robs understood.
9fingers wrote:Terrible when you have to explain humour isn't it? :lol:
Oh Lordy! I got it chaps, I was just being sarcastic! Looks like I will have to be a little clearer with my sarcasm next time… :eusa-doh:
PS Nice work Dave, looks the part. How much would they cost you normally to have them replaced by your guy?
PPS this one did remind me of something I saw on FB the other day though...
Q. What is 'Propaganda'?
A. When a Cockney has a real good hard look at something!
Next
