It is currently 24 May 2018, 05:30
Help Rewinding a motor field?
Postby Johnsbegood » 28 Feb 2016, 19:35
Hi guys. Just thought I'd ask on here whether anyone knows someone who could rewind my field from my Bosch wall chaser? Bosch very kindly have decided to cease production of the field. So I've now got a Bosch wall chaser that no longer works due to this faulty field. Everything else is fine on it bar this field. Thanks. Paul.
Johnsbegood
Re: Help Rewinding a motor field?
Postby 9fingers » 28 Feb 2016, 23:25
Johnsbegood wrote:Hi guys. Just thought I'd ask on here whether anyone knows someone who could rewind my field from my Bosch wall chaser? Bosch very kindly have decided to cease production of the field. So I've now got a Bosch wall chaser that no longer works due to this faulty field. Everything else is fine on it bar this field. Thanks. Paul.
You might find a sympathetic local rewind shop that will help. You might also be able to assist them by making a curved former to fit the existing coil from a block of wood. Having got that far, you could possibly DIY and dip the result in some electrical varnish.
Having done some digging using the part numbers of chaser field coils, several actually match with Bosch angle grinders too. Might be worth a punt?
Postby Johnsbegood » 28 Feb 2016, 23:41
Cheers bud. the part number is 1604220222. theres listings for them but when u order it they come back and say the part is now unavailable/obsolete!
i was hoping i could find someone to do it in their "lunch hour" as i reckon it would take an hour max as its not very big and it very simply done from what i can see. id even have a go myself but i would obvisouly need the correct gauge of wire and i've no experience in measuring and buying the correct wire.
Paul
Johnsbegood
Postby 9fingers » 29 Feb 2016, 00:02
That part comes from the GWS 9 -150 angle grinder 110v model
Several places I agree show no stock but Miles appear to have them
http://www.mtmc.co.uk/Bosch-GWS-9-150-C ... 84404.aspx
you might just be lucky?
Anyway measuring wire only needs a micrometer and to look up on swg tables. Some places also sell metric wire so you just need to get something as near as possible. Preferably rewind both halves to make sure they are matched. Weigh the coils as the wire is usually sold by weight not length.
Postby Johnsbegood » 29 Feb 2016, 21:02
Yeah I've tried looking in to other items that use the same field and I've ordered from that place and they came straight back saying the parts obsolete.
I was thinking I might have a go at rewinding it myself. The cable is about £10. If I mess it up I'll drop it round to a rewinders.
Cheers.
Johnsbegood
