It is currently 23 May 2018, 13:30
Starter switch part?
Postby memzey » 17 Jun 2016, 17:55
Hi everyone,
The rotary switch that controls the feed rollers on my planer thicknesser has snapped off. I'd like to replace the part rather than the whole unit as that will cost big bucks to change. Does anyone know if it would be possible to get that as a standalone part? Picture below which hopefully makes sense:
memzey
Re: Starter switch part?
Postby Tusses » 17 Jun 2016, 18:42
have you a picture of the other side ?.
Tusses
Postby memzey » 17 Jun 2016, 19:10
You mean remove the face and show the innards of the switchgear? If so then no but I can take one a bit later on tonight or tomorrow. I should also have said it is single phase.
memzey
Postby Tusses » 17 Jun 2016, 20:39
yes, I meant the innards ... if it's just an on off switch there will be many cheap options .
more so if you are not too bothered about keeping it "stock"
Tusses
Postby memzey » 17 Jun 2016, 20:59
Cool. Will post the pics when I get the chance. I'd be happy with something generic as long as it works and is safe. Easy to install would also be a bonus :)
memzey
Postby memzey » 18 Jun 2016, 12:07
As promised here are some pics of the internals of the switchgear:
When I opened the control box I found a couple of instruction manuals which will hopefully prove helpful:
memzey
Postby Tusses » 18 Jun 2016, 13:17
the switch looks pretty generic.
I'd wait for Bob to comment next :-)
He'll know better than me where to get one that fits, or he might even have one
as he does lots of starter and motor type things
Tusses
Postby 9fingers » 18 Jun 2016, 15:57
I was taking a back seat on this one as Rich was on the case..
I use this ebay seller Cropmaster for my industrial switchgear. good service good products sensibly priced
http://www.ebay.co.uk/itm/ROTARY-SWITCH ... 3f63a9c40b
This is not a perfect match as it has 3 positions but you could possibly stop it going into position 3 or just leave it.
You could message him and see if he has a 2 position version on the the shelf.
If you want to look for the perfect part either take the part number off the data sheet in your photo of search for 2 pole 2 position switches with decent current rating. the one above is 10 amps which would be good for 1-1.5hp which should be more than enough for a feed motor.
HTH
Postby Tusses » 18 Jun 2016, 16:25
I got the feeling you were Bob ! lol
if it was mine.. I'd do it without thinking .. I was happy to say it's easy and cheap ... but in this day and age, I don't like to give the final decision ! lol
Doesn't even have to be rotary (apart from the decal) toggle would do the same job.
You could argue it could be knocked ?
I'm not even sure if "we" are allowed to do our own electrical fixes , without getting them safety checked and the sicker in place ?
I guess it's different for hobby / business ?
There was a subject recently (different forums) , that you are not even allowed to put yourself at risk .. even if no one else goes anywhere near the machine .. H&S can come , spot check, and shut you down !
... now for the next job with that Dado Head ......
Rich
Tusses
Postby 9fingers » 18 Jun 2016, 16:46
Tusses wrote:I got the feeling you were Bob ! lol
Rich
A toggle would need careful selection for the current rating and would be a PITA to mount into a standard 22mm knockout that the current switch probably fits into.
Postby Tusses » 18 Jun 2016, 17:24
see .. that's why I said you :-) .. I'd have no idea what the usual size hole would be.
I'd just make a switch fit .. and I keep things like that for no reason other than it might come in handy one day :-)
Tusses
Postby Tusses » 18 Jun 2016, 17:33
I wouldn't get from china usually cheap stuff if I want it to last .. but this is the "kind of thing" I had in mind .. without the momentary preferably
and if the hole was bigger .. a couple of washers
I'd be sure to find one about my place somewhere !
http://www.ebay.co.uk/itm/Heavy-Duty-12 ... xyrjZRxCId
Tusses
Postby 9fingers » 18 Jun 2016, 18:04
Interestingly that switch too is a three position :lol:
The approach depends on the individual and the application.
I judge that Mark is making a living from his machinery and time is money. So it is appropriate to fit a part similar to the original. Something that won't stick out if HSE breeze in for example and a part that will most likely fit the hole and take the least amount of time to install.
You and I, Rich might take the view that fitting a small switch in a big hole with a couple of washers ( or machine up a pair of bushes to keep it central) is more interesting, readily available from the junk box, 100% doable on a Sunday afternoon etc is a perfectly acceptable route.
But we would not need to ask on a forum such as this would we?
Its horses for courses and I prefer to recommend a near professional solution but still one that is cost effective.
Postby Tusses » 18 Jun 2016, 21:25
9fingers wrote:You and I, Rich might take the view that fitting a small switch in a big hole with a couple of washers ( or machine up a pair of bushes to keep it central) is more interesting, readily available from the junk box, 100% doable on a Sunday afternoon etc is a perfectly acceptable route.
very much so Bob .. which is why I declined from the final recommendation ! .. and left it to you , as I know you have done that regularly for many years ! :-)
Tusses
Postby memzey » 19 Jun 2016, 00:05
Thanks guys. That's exactly the kind of guidance I was hoping to get and even a pointer on where to pick up the switch. Awesome. Just to clarify a couple of points:
I am most definitely an amateur at woodworking which is just as well given my level of "skill". Trust me - if I had to make a living doing this I'd be settling down in a cardboard box under a bridge somewhere! Other than that however Bob is spot on in that I would like to replace the switch with something easy and quick to install that won't really change the way it currently functions. I can actuate the switch by the way I just need pliers to grip the rod and turn it which is a bit inconvenient really.
I have checked and I don't think the hole is a standard 22mm knock out. In fact it doesn't look a standard anything if I'm honest:
I assume that won't make a difference as I can always drill the hole out if I need more space. More puzzling to me though is why it's so hard to find 2 position switches and whether fitting a three position one would pose any problems or raise difficulty in installation? Would I essentially just have 2 off positions and 1 on with one of those? In which case I don't see that as being a problem. Thanks again for all the help and guidance so far. It is much appreciated.
memzey
Postby memzey » 19 Jun 2016, 09:27
How about this one guys?
https://www.amazon.co.uk/dp/B00TX5QEQC/ ... zxb07S4ENQ
In the description it says 240v/440v so I assume I could wire it up 240v without too much drama?
memzey
Postby 9fingers » 19 Jun 2016, 10:24
Sourcing map have good stuff but longish delivery time from China/HK
All these rotary switches suggested have two pairs of independent switches and hence the reference to 8 terminals when you might expect only 6. one pair will be on in the 9 o'clock position, both off at 12 o'clock, and the other pair on at 3 o'clock
Wiring up is simply a matter of choosing the 4 that match the mechanical "on" position that you want to use and disregarding the other 4.
The result will be either OFF-OFF-ON clockwise or anti clockwise - your choice.
Postby Tusses » 19 Jun 2016, 13:46
if you do end up drilling .. take good precautions to keep the metal filings away from the switch gear !
Tusses
Postby memzey » 21 Jun 2016, 18:16
Spoke to Paul at Cropmaster today who did have a two position switch. It's in the post as we speak so in all likelihood I'll be looking for guidance on how to wire it by the weekend!
memzey
Postby Tusses » 21 Jun 2016, 18:22
it should be easy .. 2 in 2 out !
don't unwire the other until you are ready :-)
Tusses
Postby memzey » 21 Jun 2016, 21:42
Tricky thing is it's not the normal domestic colours being used as its 4mm 3 core flex. Can you tell from the pics above which is live, neutral and Earth?
memzey
Postby 9fingers » 22 Jun 2016, 10:13
memzey wrote:Tricky thing is it's not the normal domestic colours being used as its 4mm 3 core flex. Can you tell from the pics above which is live, neutral and Earth?
Looking at your pictures the switch seems to have two blue and two brown wires
Fit the new switch so that it connects blue to blue and brown to brown when in the ON position.
Secondary point arising from your question .... You never ever ever switch an earth lead !!
hth
Postby Tusses » 22 Jun 2016, 11:12
May I respectfully suggest you may want to get a sparky in to do it for you ..
I worry that you don't know the wire colours and how things work.
Sparky will check it's all safe after too .. and shouldn't be much more than the call out charge for such a simple job :-)
do you have a multi meter ?
Tusses
Postby memzey » 22 Jun 2016, 12:28
I have a multi meter and I also have a sparky coming round on Friday! If it were left to me I'd just look at where the wires go in the current switch and replicate that in the new one but as the Sparky is coming round to wire the shed up for me I'll ask him to do that too.
memzey
Postby Tusses » 22 Jun 2016, 13:08
good plan :-)
I hope you didn't mind me saying ? .. just you never know who's on the other end of a keyboard !
I wouldn't want to hear in the news that a fellow woodworker went crispy recently ! :shock:
Tusses
Next
