It is currently 29 Mar 2024, 01:42
Andyp wrote:Malc, thanks I use the iPlayer Radio a lot.
A lack of suitable devices in the kitchen make this a little problematic at the moment. This could be easiliy solved of course with Christmas approaching, if there is no other option.
9fingers wrote:Wall warts get round so many H&S design problems that nearly every manufacturer will use them.
Andyp wrote:So further supression of the Camvac is a non-starter?
I do not mind having another radio but a carting round a combination of gadgets will be too much trouble for me and even more so for the missus. I want to be able to just switch something on and press a button to find the right station.
Andyp wrote:Thanks Bob, I'll have a look out for something here. Roberts are expensive here but if I buy in the UK I'll have to buy another wall wart.
Tusses wrote:could you Faraday cage the camvac ? tin foil ?
9fingers wrote:Tusses wrote:could you Faraday cage the camvac ? tin foil ?
Long wave frequencies will crawl out along the wiring. It really is a difficult problem to suppress and the radio will have turned itself up to maximum gain to receive a weak signal only a few uV above noise.
A lost cause especially as every previous episode of desert island discs ever broadcast is available on iPlayer.
Andyp wrote:.............
So if I cook there is no problem and we get roasties rather than mash.
Tusses wrote:I do most of the cooking
Tusses wrote:.. as I prefer it ..
the cooking and the result
Andyp wrote:Tusses wrote:I do most of the cooking
So do ITusses wrote:.. as I prefer it ..
so do WE.
RogerS wrote:This business about not streaming outside the UK...how do they technically manage this? Your IP address ? If so could you not use a UK proxy ? Or the TOR browser.
