It is currently 28 Mar 2024, 12:39
Dead CamVac motor
Re: Dead CamVac motor
Postby 9fingers » 07 Aug 2019, 10:40
RogerS wrote:
9fingers wrote:....
Aldi have a workshop vac for £50 instore and online at the moment. just sayin' :lol:
I've got one of those permanently connected to the Kapex. No good for the table saw as that is large diameter...4" plus
My TS seems Ok with HVLP extractor with a proper (induction) motor.
Can to you tell that I avoid brush motor devices whenever possible? :lol:
Postby RogerS » 07 Aug 2019, 10:54
9fingers wrote:Not sure about the glow, could be a reflection?
Is this test with no earth connected?
Yup...no earth. Motor runs much slower, speed varies and the commutator gets red hot ...as in a bit of water on the end of the finger and a quick dab and it goes ''''hiss"""
The springiness is the same in both brushes.
Time to flash the cash.
Postby RogerS » 07 Aug 2019, 11:06
9fingers wrote:
RogerS wrote:
9fingers wrote:....
I'll try mine. Guess my thinking is 'legacy' in that I originally used the Camvac when I had the drum sander and other dust creators and was taking my 'clean' chippings away to a local stable. That was then. This is now and all goes down the tip.
Postby Andyp » 07 Aug 2019, 11:33
Roger have you readthis thread?
viewtopic.php?f=23&t=1132
HJ was looking at a numatic motor to replace his camvac one as they were cheaper. No mention as to whether he did or not might be worth a PM.
Postby RogerS » 07 Aug 2019, 12:32
Andyp wrote:Roger have you readthis thread?
Thanks Andy..good find.
Postby RogerS » 07 Aug 2019, 13:36
Thanks Andy :eusa-clap: He got back to me very quickly. Just ordered one off Amazon £28 result !!!
Postby Andyp » 07 Aug 2019, 14:47
Can you post up the details of the motor you ordered? It might prove useful to have a reference to it in the future.
Postby 9fingers » 07 Aug 2019, 14:56
Just goes to show that it is always worth looking around for sources of spares other than the retailer of the machine. Firms the size of camvac (or their new owners RP) will not have a custom made motor unless they cannot avoid it and so will look at existing parts from "motors-R-us" and design their product around what is on the market.
The same goes for bearings and belts - nearly always standard parts and readily available.
Postby RogerS » 07 Aug 2019, 16:05
Andyp wrote:Can you post up the details of the motor you ordered? It might prove useful to have a reference to it in the future.
Here it is
https://www.amazon.co.uk/dp/B013WP3FI8/ ... 11_TE_item
Lots of others as well.
Postby Malc2098 » 07 Aug 2019, 18:00
Talking of Henrys.........this video may be inappropriate for some viewers.
[youtube]TRoTwe5biWk[/youtube]
Postby RogerS » 10 Aug 2019, 12:21
Not so straightforward :(
On the original motor there are four tapped holes (blind) in the casting that the motor is attached to. Into these holes go four threaded rods that then attach the motor to the top plate of the Camvac.
On my replacement motor, none of the holes are tapped. Two of them are slightly undersize and as the casting is softer than the threaded rods, I was able to self-thread the rods into them. But the remaining two are slightly oversize and the only thing I can think of is to Araldite the rods in.
To make matters worse, the thread is definitely not metric
EDIT: Damn..just watched a video on replacing the motor in a Numatic Henry and the assembly makes no use of any threaded rods and so those holes are as per (as it were). Looks like it has to be Araldite.
Postby 9fingers » 10 Aug 2019, 12:58
Full lead (slow cure) araldite or JB weld will be fine.
Or slower, I can loan you a tap?
Postby RogerS » 10 Aug 2019, 13:06
9fingers wrote:Full lead (slow cure) araldite or JB weld will be fine.
Gluing up as we speak, Bob, but thanks for your offer.
Postby 9fingers » 10 Aug 2019, 13:29
No worries. Another time I have a good selction of britsh, american and metric taps and dies.
Postby RogerS » 10 Aug 2019, 14:10
Also might have to faff around with the base. Still cheaper then buying a new Camvac !
Postby RogerS » 11 Aug 2019, 05:57
Silly question...these motors don't worry about which wire goes to L or N ? I don't think that they do.
Postby 9fingers » 11 Aug 2019, 07:36
No single phase AC motor is polarity sensitive.
The voltage changes polarity every 10mS
Postby RogerS » 11 Aug 2019, 08:02
9fingers wrote:No single phase AC motor is polarity sensitive.
LOL !
Postby RogerS » 11 Aug 2019, 10:53
All now sorted and so thanks to all. :text-bravo:
All for the princely sum of £28 which I call a result.
Postby Rod » 11 Aug 2019, 13:12
Well done that man.
On the subject of motors, my Proxxon belt sander produced copious amounts of smoke on switch on.
I bought it refurbished from Axminster a few years ago and have hardly used it.
Anybody know if Proxxon or Axminster carryout repairs?
Postby 9fingers » 11 Aug 2019, 13:38
Rod wrote:Well done that man.
When we had a show round at axi a few years back, - I think you were there Rod, they had a workshop repairing stuff but I don't recall if it was just doing warranty work on their imported machines or if they tackle all machine they sell.
After the smoke does it run OK? sometimes is is just filter capcitors that emit smoke after a brief bang.
Brush motors tend either run OK or run slow and produce lots of extra sparks round the comutator.
Usually ok to use if it is just capacitors as they fail open circuit but if it does not run properly, it is normally beyond economic repair as replacement armatures are similiar price to the original tool plus labour to fit.
Postby Rod » 11 Aug 2019, 17:33
I bought it on that trip Bob.
No smoke this time but a clicking noise, when I wound up the speed, it tripped the fuse.
Postby 9fingers » 11 Aug 2019, 17:55
I see that brimark are sole agents for proxxon and owners of Axminster so I'd contact them to find out service arrangements.
Postby Rod » 11 Aug 2019, 22:18
Thanks Bob I’ll give them a go.
Postby Rod » 14 Aug 2019, 20:10
Contacted Axminster, repair likely to cost £87.
New ones £106!
PreviousNext
