It is currently 29 Mar 2024, 15:09
by Woodpile » 31 Mar 2015, 18:34
My bandsaw has been strugling to start for some time, on occasion I have had to help it start by forcing the teeth of the saw down to get it going, am I right in thinking its probably the start capacitor?
Stew
Edit - the motor hums when I power it up but doesn't turn
Woodpile on 31 Mar 2015, 20:49, edited 1 time in total.
Woodpile
- Seedling
- Name: Stew
by 9fingers » 31 Mar 2015, 19:03
There are three possible causes but the most likely by far is the failure of the starting capacitor.
these are common standard parts and there is no need to pay silly money for a manufacturers spare. Ebay is you best source. match the capacitance as closely as possible and the voltage should be at least as high as the old one. Types with either spade tags or flying leads are available. Choose the easiest to fit to suit your motor.
If you get stuck post a crystal clear photo of the lettering on the capacitor and the motor plate and I'll try and help.
- Petrified Pine
- Location: Romsey Hampshire between Southampton and the New Forest
- Name: Bob
by Woodpile » 31 Mar 2015, 19:23
Thanks Bob, I seem to recall you giving advice about start capacitors to someone in the past, I've taken the cover off and the cap is bulging, I've found a replacement on ebay for just over £6 delivered, thanks again Bob.
Stew
Woodpile
- Seedling
- Name: Stew
by 9fingers » 31 Mar 2015, 19:35
It is one of those fixes that does not cost much and has a very high probability of success and won't do any harm as capacitors do degrade with time.
Should this not work, then the next area to examine is the centrifugal switch inside the motor.
The nightmare final fault is a failed start winding which requires either motor replacement or a rewind but this is a pretty low probability.
- Petrified Pine
- Name: Bob
by Woodpile » 31 Mar 2015, 20:52
Bob I've just noticed the subject title, stupid me put Motor want start, now I don't want people to think I'm thick so I go and change it to Motor won't start, only it doesn't change the replys before I changed it, God am fick
Stew
Woodpile
- Seedling
- Name: Stew
by 9fingers » 31 Mar 2015, 21:05
There! I waved my moddy magic wand and it is all fixed for you Stew.
- Petrified Pine
- Name: Bob
by Woodpile » 04 Apr 2015, 16:01
9fingers wrote:There! I waved my moddy magic wand and it is all fixed for you Stew.
Thanks Bob
Just wanted to let you know I've just fitted a new cap (£4.15 & free P&P from ebay) and it's working a treat again.
Stew
Woodpile
- Seedling
- Name: Stew
by 9fingers » 04 Apr 2015, 16:10
Excellent News!
Another victory of Man over Motor.
- Petrified Pine
- Name: Bob
Users browsing this forum: NickM and 6 guests
