I bought a 1hp dust collector quite quickly after buying my planner thicknesser to stop the shavings dropping back into the machine and marking the surface finish as they got crimped under the freed rollers.
I worked OK but was not good at collecting the fine dust which came out though the cloth filter bag.
I then built a cyclone, using plans from Wood magazine, taking the blower of the orginal machine to power it, this has worked well, but I now have more machines and therefore more soil pipe work connected to it, the 1hp motor was not keeping up with the expansion.
A few weeks ago I had an email from Axminster advertising a machinery sale, and there was a 3hp dust collector listed, so I bought one.
IMG_20150611_181615 by Dave, on Flickr
Large box delivered while I was at work.
IMG_20150611_183538 by Dave, on Flickr
this was what I was after, the spec looked good
IMG_20150611_183456 by Dave, on Flickr
just look at that air flow.
I use remote control sockets to control the collector, this new motor would be a problem, the start up surge would almost certainly blow the internal relay, also the NVR needs to be removed.
IMG_20150704_194221 by Dave, on Flickr
On opening the boxes on the new motor, it looked a bit more complicated than for the old one. I bought a relay, 240v coil with changer contacts rated at 30A.
IMG_20150704_194235 by Dave, on Flickr
It turned out that this motor had a thermal overload wired into the NVR to kill the feed if it got too hot, the A1 contact is the hold in coil and is feed though the overload circuit.
IMG_20150704_194619 by Dave, on Flickr
The smaller black and brown wires are connected to the overload contacts.
I removed the NVR completely, I used a scrap bit of Perspex to close the hole where the NVR had been mounted.
IMG_20150705_165253 by Dave, on Flickr
The new relay is inside the box, there are now 2 mains leads, the original black one provides the power, its connected to the relay contacts, while a new grey mains lead is used to control the relay, it is in series with the overload contact. The grey lead is plugged into the remote control socket, the fob now turns on some major suck when required, I don't think I will have as many problems with stuff laying in the pipe work.
Sorting the electrics was the easy bit, I had to disassemble the cyclone off the wall and remount it a few inches to the right, the new motor hit on a rafter, that was a hot dusty job, I was well pleased when it was finished.
I still need to sort out a warning system for when the dust bin is full.
