It is currently 29 Mar 2024, 08:24
tracerman wrote:Terry - extraction is a favourite subject of mine as may already be apparent so I of course admire the trouble you are going to and I hope it all performs for you . I also particularly admire the way in which you did not tidy up for the sake of the photos so we are seeing you as you really are . ( LOL) . Looking forward to a final report on that system . ( but is it ever really over ? )
Nice work anyway .
Steve
Doug wrote:Looking good Terry, could I ask if the take off from the main outlet on your bandsaw to what looks like the underside of the table is factory fit or a modification? Also how well does it work?
My crappy old Axminster bandsaw has two 4" take offs but I've never got satisfactory extraction from it even when running two extractors, one off each port which is also a bit of a pain.
Jimmy Mack wrote:Out of interest... Do you earthbond your Spiral duct to ground any static? Effectively it would be bonded if the continuity is maintained back to the motor housing and controls, but it could be lost over the (wooden) blast gate junctions?
Jimmy Mack wrote: ...a potential reality...
Use only conductive materials for ductwork so that any static electricity generated can be discharged to earth.
Users browsing this forum: Google [Bot] and 16 guests
