It is currently 28 Mar 2024, 22:20
Planner blade setup - confusion overtakes logic
Postby justaskin » 13 Apr 2016, 07:55
I have just seen a Utube article on blade setup with magnets attached to a strip of wood all level on the out table, Then rotate the blade block so the top of the blade is TDC then let the last magnet lift the blade then tighten the locking block bolts.
I tried this but test strip of wood on the out table wouldn't move the recommended 3mm ish, as the blade was never in contact.
So which or who is correct is there any advantage?
Richard
You think its difficult try herding cats
justaskin
Location: Shenley Church End MK(the legion of the lost)
Re: Planner blade setup - confusion overtakes logic
Postby Doug » 13 Apr 2016, 08:23
Have you tried planing a piece of timber with the new set up?
Over the years I've read many ways on setting up blades but the proof is in the planing.If your blades are dead level with the outfeed table they won't move your piece of wood but should still cut.
Doug
Postby justaskin » 13 Apr 2016, 09:40
Hi Doug
No I haven't tried using this setup yet, I was wondering the pro nd cons, I agree it should cut but what will happen if you now hold the planed portion to the out table with the in table set at say 1/2mm.
I do not need a disaster at my stage of life.
Richard
justaskin
Postby DaveL » 13 Apr 2016, 09:56
justaskin wrote:what will happen if you now hold the planed portion to the out table with the in table set at say 1/2mm.
It should take a 1/2mm cut.
I have a Wadkin blade setting tool and set the blades on my Multico planer to be level with the out feed table, the wood should be feed across the cutter head and once there is enough to hold it down the pressure should be on the out feed table side.
Regards,
DaveL
Postby memzey » 02 Jun 2016, 21:50
Try a slip of copier paper under the wooden strip. Should be about 4 thou which is the right sort of projection. A lot depends on how straight your wood is and how flush with that wood your magnets are.
memzey
Postby TrimTheKing » 08 Sep 2016, 11:21
Did you get this sorted in the end?
