9fingers wrote:There you go!
Thanks Bob, although I was worried you might produce something like that.
Let’s see if I understand it.
1) My existing RC socket plugs into an existing wall socket.
2) A box containing the relay plugs into the RC socket.
3) The Camvac plugs into the box containing the relay.
What I would like to do is use a surface mounted double socket like this
http://www.castorama.fr/store/Double-pr ... ction=jumpOne socket is used for the Camvac, the other socket to be removed and will house the relay, I‘ll have to check that it will fit.
All that remains for me to understand is how to connect the relay to
a) the cable with a plug on the end that plugs in to the RC Socket and
b) the socket that the Camvac will plug into
Am I getting there?
