It is currently 29 Mar 2024, 07:24
ooh ! I might have a question for Sir Bob ! extractor motor
Postby Tusses » 25 Aug 2016, 20:38
SIP dust extractor ..
I'll have a look myself 1st ,when I get a chance, and report back
symptoms so far .. not used it for a couple of weeks
pressed play and nothing .. hand on motor, I could feel it trying.
hose off, and spin the fan with a pencil up the hole, and the motor slowly spins up , but doesn't get very fast.
1st though was the cap .. but I hadn't noticed before .. no cap ?
I'll take the lid off the box when I get a chance, maybe a small cap inside ? .
either way, I'll report back :-)
Tusses
Re: ooh ! I might have a question for Sir Bob ! extracto mo
Postby 9fingers » 26 Aug 2016, 07:41
Extremely unusual for there to be no capacitor on all but the most feeble of induction motors. More info needed to prevent unnecessary speculation.
I'll be otherwise occupied most of today but will look again on Saturday.
Postby Tusses » 26 Aug 2016, 20:26
no hurry Bob .. I have to get the down time to stop and take the switch cover off and have a looksee
this is as much as I know so far
Tusses
Postby 9fingers » 26 Aug 2016, 22:13
I'd put money on there being one if not two capacitors inside that box underneath the the NVR switch.
Postby Tusses » 26 Aug 2016, 22:28
when I get round to looking at it, can I raid my scrap/spars bin for caps ? .. mostly audio/psu , or do starter caps have some other peculiarities ?
Tusses
Postby kirkpoore1 » 26 Aug 2016, 23:03
Tusses wrote:when I get round to looking at it, can I raid my scrap/spars bin for caps ? .. mostly audio/psu , or do starter caps have some other peculiarities ?
You have to look at the ratings in voltage and microfarads (uF). Anything over 240v will be fine, but the capacitance should be reasonably close to what's in there.
Kirk
kirkpoore1
Postby Tusses » 27 Aug 2016, 08:05
I was thinking more of polarity issues ?
Tusses
Postby 9fingers » 27 Aug 2016, 08:12
Indeed. Electrolytic capacitors are no good for this application and I would go for voltage ratings around 400v.
Motor capacitors are very cheap on eBay and you are possibly better off with a new one.
Re: ooh ! I might have a question for Sir Bob ! extractor m
Postby Tusses » 16 Sep 2016, 17:31
finally took the cover off ...
As you said Bob, there it is in the casing
Looking on ebay they're about £3.50 .. like this ..
http://www.ebay.co.uk/itm/Universal-10U ... SweWVXf~Vv
what do the numbers mean under the 450VAC ?
Mine says 40/70/21
the ebay one says 25/70/21
Should I just buy the cheapest ?
Rich
Tusses
Postby DaveL » 16 Sep 2016, 20:00
I think those numbers are the climatic ratings for the capacitor, the first is the lowest temperature -40 , the next is the highest temperature +70, but I cannot find the last one defined, sorry.
So the replacement one you are looking at will be OK a so long as you don't move to the north pole.
Regards,
DaveL
Postby 9fingers » 16 Sep 2016, 20:39
+1
Postby Tusses » 20 Apr 2017, 17:25
well , it's been a while !
whilst I re-cooperate, I've been fixing stuff.
Finaly go round to putting that capacitor in.
It ran great for about a minute and then broke again. motor slowed, and made an unpleasant noise.
I'm guessing the start/run switch , inside the motor is the cause ?
If so, are these cheap motors serviceable ?
Tusses
Postby 9fingers » 20 Apr 2017, 18:52
Open it carefully and you might find the switch is fixable. Take it steady and observe how the mechanism works and which way round things go (photos to document) WATCH OUT FOR PING-**CKITS
You almost certainly cant get spare parts for these switches but sometimes you can fashion parts out of phosphor bronze sheet.
PS what is the big white lump with the black leads coming out?
Postby Tusses » 20 Apr 2017, 20:30
the white lump is the cap in a sleeve
I'll make some workbench space before I attempt dissmantlement
Tusses
Postby 9fingers » 20 Apr 2017, 20:37
Tusses wrote:the white lump is the cap in a sleeve
Ah OK the crease is the sleeve made it look like a rectangular block.
