It is currently 17 Mar 2018, 07:26
Solving a band saw problem
Postby justaskin » 24 Oct 2016, 07:06
I was having problems setting up with sloppy rotating blade side discs. Turned up some some lignum vitae dowels to fit. Works a treat in resaw and veneer mode.
You think its difficult try herding cats
Location: Shenley Church End MK(the legion of the lost)
Re: Solving a band saw problem
Postby Andyp » 24 Oct 2016, 07:40
A very nice man had already replacd the guide blocks on my BS with LV. Works a treat.
If anyone needs some small pieces of LV I have quite a lot and would be happy to share.
Postby Woodbloke » 14 Nov 2016, 19:41
:text-goodpost: - Rob
Postby Mike G » 14 Nov 2016, 20:30
I've found bits of beech work perfectly well. In fact, end grain, i reckon almost any hardwood would do the trick.
