It is currently 22 Jan 2019, 21:40
Trouble changing table saw arbour
Re: Trouble changing table saw arbour
Postby Tusses » 29 Nov 2016, 12:46
9fingers wrote:
Tusses wrote:I haven't read the whole thread .. oh .. lol "thread" ! .. but are you trying to turn the right way ? if it's a left hand thread, due to the motor spin direction, then you need to turn the other way !
just putting this out there, in case no one has mentioned it :-)
Yes we are well passed this potential hurdle :lol:
:lol: good ! .. just that it's so obvious, it might have been overlooked.
I have one of those "pen" butane tourches I use for tight spaces . Car Brake nipples is what it is most used for ! .. ooh .. nipples .. :lol: :D
Tusses
Postby Tusses » 29 Nov 2016, 12:47
this sort of thing ..
Tusses
Postby Hot stuff » 29 Nov 2016, 17:41
It may have been fitted using some sort of loctite if the previous owner was concerned about it loosening when in use. Best way to heat it and soften any thread lock without damaging surrounding areas is using a hot air gun or hair dryer if that's easier. It'll take a while with just a hair dryer but worth a try before you get started with the big hammer technique.
Hot stuff
Postby Andyp » 29 Nov 2016, 18:19
HI Hot Stuff and welcome to the forum.
Postby Tusses » 29 Nov 2016, 18:23
Andyp wrote:HI Hot Stuff and welcome to the forum.
yes , from me too ..
but can't miss the "Hot Stuff" and hot air gun pun ! :-) :lol:
Tusses
Postby Wizard9999 » 30 Nov 2016, 09:47
Well, not surprised the arbour is hard to take off. I sent a message to the person I bought the saw from and he has told me he fitted the longer arbour soon after buying the saw and never changed it again. So that arbour has been on for a fair few years.
It has been suggested I give Woodford Tooling a call to ask if they have any experience and / or suggestions, can't see there is anything to lose so I will do that later this morning. Other than that I need to sort out a more robust length of pipe to act as a lever and I need to look into cutting down the Allen key as a pipe thicker than the curtain pole won't go onto the Allen key at the moment.
Terry.
Wizard9999
Postby Tusses » 30 Nov 2016, 12:25
my go to for a leaver on an allen key is a ring spanner.
There is only so much leverage you can put on an allen key, before you chew the end off .. or worse, damage the arbor
if there is room, you can get hex bits for socket wrenches.
Tusses
Previous
cron
