It is currently 29 Mar 2024, 07:43
Doug wrote:If you look in the second picture in your link you will see the transformer Paul
I'd also suggest you search WWUK for Ceros before buying one, just one thread I remembr
http://www.woodworkuk.co.uk/forum/viewt ... os#p131035
Rod wrote:Reading the blurb it seems to be but perhaps a phone call to check
Pinch wrote:.....Rutlands are showing what looks like a darn good 66 piece set http://www.ebay.co.uk/itm/TCT-Professio ... 3641.l6368
Andyp wrote:Paul, and others, what does the Mirka ROS do that the Metabo does not, I have had one for more than 10 years and it has been faultless. Even managed to sand 2 oak parquet floors in the girls bedrooms.
Is it just the quality of the abrasive sheets? Or the extraction? Or does it not leave the tell tale circular marks that all other ROS seem to leave. At the price the Mirka must do something extraordinary.
Jimmy Mack wrote:It's a bit more wonga ... with the DEROS there's no bulky transformer and you get the 125mm pad kit and carry case.
Perhaps not a biggy if you have a permanent sanding station set up. See if you can try one at a dealers...I think Mirka have mobile demo reps...not sure.
Jim
RogerS wrote:Pinch wrote:.....Rutlands are showing what looks like a darn good 66 piece set http://www.ebay.co.uk/itm/TCT-Professio ... 3641.l6368
I've never seen the words 'Rutland' and 'quality' appear in the same sentence.
TrimTheKing wrote:RogerS wrote:Pinch wrote:.....Rutlands are showing what looks like a darn good 66 piece set http://www.ebay.co.uk/itm/TCT-Professio ... 3641.l6368
And you didn't in this one either, unless I'm blind…
Pinch wrote:TrimTheKing wrote:RogerS wrote:[quote="Pinch"].....Rutlands are showing what looks like a darn good 66 piece set http://www.ebay.co.uk/itm/TCT-Professio ... 3641.l6368
Users browsing this forum: No registered users and 25 guests
