It is currently 29 Mar 2024, 15:11
RogerS wrote:I had a similar sound on my Sedgwick and it turned out to be the fan blades (plastic) slipping on the motor shaft.
Robert wrote:Sounds like V belt(s) slipping to me.... assuming it has them of course
edit. just read your post properly. Still sounds like belts. Was there any change in the sound after changing tension?
9fingers wrote:To try and locate the source, take the belt(s) off and see if it still does it.
Curious to see flat belts on a modern saw. In the old days, flat belt drives sometimes needed applications of so called "belt jam" jollop but not even seen that for sale in decades.
If so does the brake run hot with protracted running? if so suggests it is not releasing properly and needs adjustment. Whilst you are in there see if the fan could be slipping but I doubt it on the new motor.
9fingers wrote:...2 out of 10 for observation lol...
Jimmy Mack wrote:9fingers wrote:...2 out of 10 for observation lol...
I've put some more tension on... Still screeches at me
Is there something I can apply to the belt to make it more grippy? Or perhaps it's the quality of the belt rubber.
I'm not sure if this is my responsibility or the supplier of the new saw
Coley wrote:https://www.toolstation.com/shop/p25485?r=googleshopping&rr=marin&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&gclid=EAIaIQobChMIzuzp7tOc2wIVLLftCh2bVgI-EAQYASABEgLlK_D_BwE
This will sort out your slipping issue
Coley wrote:Yeah might do Bob. I was only answering his question
