It is currently 29 Mar 2024, 10:53
by themissingelf » 29 May 2018, 18:20
I've decided my garage / workshop is too small for a dust extraction "system".
Instead I want to place my DX5000 somewhere reasonably central along the length of the garage and connect it directly to whatever tool is being used at the time. I'd like to avoid the hose constantly trailing on the ground; attaching it to an arm that allows it to be moved about the workshop and life up out of the way when not in use.
Is anyone aware of such a device?
Thanks
themissingelf
- New Shoots
- Name:
by old » 29 May 2018, 19:03
Make one to fit your needs with ply nuts and bolts etc.
old
- New Shoots
- Name: Chris
by Doug » 29 May 2018, 20:46
Festool do a boom arm which whilst expensive is worth looking at to get ideas.
I fixed an 8’ length of 1” dowel to the ceiling of the workshop, made a sliding carriage to run on the dowel from a piece of plastic pipe to which I attached my extractor hose, it works very well & the hose doesn’t get in the way trailing as it does from the ceiling.
Doug
- Old Oak
- Name:
by Rod » 29 May 2018, 21:02
I don’t think there’s anything commercial but you could rig up a wheeled base to push it around.
Don’t forget that it’s very heavy when loaded with chippings etc.
- Old Oak
- Name:
by themissingelf » 29 May 2018, 23:37
Doug wrote:Festool do a boom arm which whilst expensive is worth looking at to get ideas.
Inspired! Thank you!
themissingelf
- New Shoots
- Name:
by RogerS » 30 May 2018, 15:13
Any pictures, Doug ?
- Petrified Pine
- Name:
