It is currently 05 Jun 2020, 10:02
Ks120 fettling
Ks120 fettling
Postby Bucks woodshop » 01 Jul 2018, 19:10
Well i spent a few hours today fettling my ks120 made a couple of cockups see if you can spot them
I dont like the adjustment for vertical zero but the horizontal indents were spot on
Dust collection is really good best ive seen on a mitre saw
Again i find trenching the best ive seen on a mitre saw
Was a proper faf to get the lasers right in the end ive found my zero clearance insert is a better guide
2 things i used peter parfitts measurments for the insert and 7.5 is too thick for the base insert
Also be carefull with the back fence thickness as the supplied clamp is very close to the fence so if you want to use it you will need to make adjustment for that
Love the saw though and the angle guage is brill i did some skirting and i didnt need to fettle it at all Image
do or do not do there is no try - Yoda , the dagobah system
Bucks woodshop
