It is currently 29 Mar 2024, 10:00
will1983 wrote:Could you not replace the Allen bolt with a standard hex head???
Coley wrote:.....
What are you gonna get instead ?
StevieB wrote:On mine (admittedly a few years old) there are 3 bolt holes under the clamp so you can widen the piece of timber you can accommodate by moving the clamp back in its entirety - have you taken the clamp off to check there is not more than one hole?
StevieB wrote:Extra piece of timber as a spacer on the wider setting? I have done that before to get the mortice position I needed.
DaveL wrote:So Roger, did you just bolt the wheels on to the thin sheet metal the cabinet is made from?
I think you should have able to put the wheels on but you need a sub base of ply or OSB to make the wheel mounts wrong enough.
TrimTheKing wrote:Appreciate you have stuff to do Roger, but I would still be tempted to send it back and tell them to bring a temp replacement for you to use. They need to see if their manufacturing is crap and whether they need to/want to do something about it...
Think of the people to follow you, who don't have the technical nous you do to notice and self repair deficiencies...
Doug wrote:Buy an XL domino Rog I use mine for cutting all mortises, ok I have to square the corners for tradition joints but I find it easier taking the tool to the timber, the extraction is excellent & it’s quicker to set up, I sold my mortiser not long after buying the domino as I wasn’t using it.
As for Axminster I’ve been saying what you’ve found recently for a couple of years, customer service begins with supplying quality products fit for purpose not using the customer as quality control, of course they will bend over backwards to rectify faults with their gear because they know full well these faults exist, the sad part is they are happy to sell these tool knowing this.
