It is currently 28 Mar 2024, 12:37
Robert wrote:It would be too tall for where I intend to store it if it was on top.
Think I've worked out how to do it now. Clamp an 8ft timber to the tables and position a trestle near each end of the planer. lift one end at a time onto a stack of flooring offcuts on the trestle tops. take the pallet away and raise one end, remove one 18mm plank, lower then down the other end and repeat.
I'll sleep on the idea first. May go and get a bigger timber plank than I have to hand.
Not crazy about the mobile base. Think fixed wheels one end is going to be a pain. Like the lever down feet instead of locking castors and it feels strong. Had to hack saw down 2 bars as the minimum size is still a bit large. Wheels are hard nylon so may be possible to just skid them sideways. Otherwise I may need some kind of lever down castor between the fixed wheels. We shall see.
eezageeza wrote:i think thats the model that Peter Parfitt bought recently (NewBritWorkshop on Youtube).
Have a look at his video to see how he got it off the pallet etc (it was a bit precarious frankly, but might be interesting for you to see).
eezageeza wrote:Interesting that you have this running on a 13 amp supply - I'm working up to buying a P/T in that sort of class (maybe that very one) and they all seem to call for a 16 amp supply (which I don't currently have). Axminster spec a type C breaker as well.
Do you have a type C circuit breaker on your supply? Does the machine run perfectly well on your supply?
I have a Record Power Sabre 350 bandsaw, and starting that causes the shop vac to dip in speed for a fraction of a second as the saw picks up speed, so I'm suspicious that a P/T with a bigger motor might be a step too far.
I dont think installing a 16 amp supply would be horrifically expensive, but would be happy not to bother if I didn't need to!
9fingers wrote:My advice would be to get the machine you want and try it on your supply to see what if any upgrades you need to install. You could be pleasantly surprised.
Users browsing this forum: Bing [Bot] and 10 guests
