It is currently 29 Mar 2024, 11:09
Axminster belt grinder
Postby Woodster » 20 Oct 2018, 11:02
Has anyone else noticed the new Axminster “Ultimate Edge” belt grinder on pages 240 and 241 of the new catalogue?
I’m not in the market for one as I sharpen my tools on a much modified and larger belt and disc sander. It does seem a shame though that the Axminster doesn’t compete a bit better on price with the Sorby ProEdge.
For those without a catalogue it’s here:
https://www.axminster.co.uk/axminster-t ... tem-103474
And here:
https://www.axminster.co.uk/axminster-t ... tem-103473
Re: Axminster belt grinder
Postby RogerS » 20 Oct 2018, 12:13
I have to admit surprise that one could actually sharpen chisels etc on what essential is a bit of moving sandpaper and I'm guessing flopping about. Caveat ...I base this observation on my own linisher which is, admittedly, a much larger beast but I certainly wouldn't even attempt to use that to sharpen my chisels.
You live and learn !
Surely it's a load of faff to keep going down through the grades and changing the belt ?
Give me my Worksharp 3000 any day.
Postby Woodster » 20 Oct 2018, 14:26
I generally sharpen all my tools, both metal and woodturning on my belt and disc sander using just a 80 grit belt. If I want a more polished edge I use or finish off with a 240 grit belt. Changing belts on my machine only takes about 20-30 seconds. I can get grits from 50 up to 600 for my Record BDS250. I understand that the Sorby ProEdge came about because Sorby used a large belt sander in their factory to sharpen all their tools prior to dispatch. Actually most tools seem to come with a flat grind.
Postby selectortone » 20 Oct 2018, 15:42
RogerS wrote:I have to admit surprise that one could actually sharpen chisels etc on what essential is a bit of moving sandpaper and I'm guessing flopping about.
A really sharp chisel isn't what is needed for woodturning - the process of turning wood takes a very sharp edge off pretty quickly. What you need for turning is a decently sharp edge that stays that way for a good time, which is why HSS, M42 and carbide tools are popular with turners. Carbon steel, the tradional material for turning tools, can be sharpened to a keener edge but being softer it doesn't stay that way for long when the item you're cutting is whizzing around at a thousand revs or so, hence its fall from grace with turners.
For sharpening my turning tools I use a bench grinder and a white or CBN wheel. It works fine for me and most importantly the grinder is right by my elbow so there's the minimum of time away from the lathe. If I want a really sharp chisel for the very occasional bit of guitar repair work I do nowadays, I'll do it by hand on a whetstone with my Veritas honing guide, as I was taught at guitar-building school.
selectortone
Postby selectortone » 20 Oct 2018, 17:08
p.s. I don't think Axminster Tools loves me any more (despite all the money I've given them!)... still no catalogue for me :eusa-violin:
selectortone
Postby Woodster » 20 Oct 2018, 22:17
The postman’s still got it in his loo, soon as he’s finished reading it he’ll pop in through your letter box! :lol:
Postby selectortone » 20 Oct 2018, 22:25
:lol:
selectortone
Postby selectortone » 21 Oct 2018, 13:29
Woodster wrote: It does seem a shame though that the Axminster doesn’t compete a bit better on price with the Sorby ProEdge.
What am I missing here? It seems like a lot of money for what is essentially just a drive wheel and tensioning wheel bolted onto the end of a motor.
For less than a third of the price you can buy one of these from Machinemart with the same spec in terms of motor power and belt speed. You even get a disc sander.
It looks a bit agricultural but it's a big old solid lump of cast iron. I've had one for a few years and it does everything I need in terms of rough sanding and shaping (don't use it for sharpening though). We had one at the guitar repair shop where I used to work and it got lots of use for roughing out blanks for bridge saddles, nuts and whatever. That one's been going for ten years.
selectortone
Postby Woodster » 21 Oct 2018, 18:42
Some of the increased cost is no doubt in the micro adjust tool holder but it’s still expensive in my view.
I would need to try out both but on the face of it I prefer the Sorby approach of using all steel construction.
I’m still surprised the Chinese haven’t copied the ProEdge and knocked it out at £150.00. :?
Postby wallace » 23 Oct 2018, 09:51
I've been using a disc and belt sander for years for my turning tools. It has a very heavy cast base. That price seems a bit silly to me.
I missed a big boys wadkin belt sander last night. It went for just over £100. I blame the mrs
wallace
