It is currently 29 Mar 2024, 07:37
Making custom spindle moulder cutters
Postby RogerS » 10 Dec 2018, 08:01
I thought that some folk might be interested in the process I go through when making up custom spindle moulder cutters.
Guess the first question is ‘Why would you want to use them ?’. A couple of reasons spring to mind.
Method 1 - is to match an existing profile in a door or window etc that one is making a replacement part for. For this my preferred method is to get some cling film and two-part car body filler. Mix up some filler, take a sheet of cling film and put it over your palm, slap the filler on top followed by another sheet of cling film and then hold the whole lot over the original moulding making sure you get the filler into all the nooks and crannies in the original moulding. It can get a bit warm while the filler hardens. Once hard, take a slice through the filler that is now a profile of your moulding, draw up/photograph/whatever and send it to your preferred supplier of custom cutters.
Method 2 - is often used when, for example, you want to create a period moulding on a door or architrave and the pattern for the moulding is not available from usual sources.
But first a bit of history. Our house was built in 1754. In the 1960’s, there was a plan to build a large reservoir in the North East. Two sites were in play - one based around the Irthing Gorge and the other Kielder. A London-based couple - the Darlings - bought the house together with a swathe of river frontage. Had Irthing got the go-ahead then they reckoned they’d be sitting on a tourist trap AKA gold mine. But Kielder won the day and the Darling bar stewards simply walked away and let this Georgian house rot. By the mid-1970’s all that was left were the gable ends, the back wall and some of the front wall. The roof had totally gone so allowing all the original Georgian interior to rot. Bar stewards. The house was eventually bought back from them in the 1970’s and renovated - after a fashion. Architraves made from decking, for example !
We’re trying to bring back a little bit more authenticism. So CD (Chief Designer) carried out some research and liked this door by Robert Adams - designed and made at a similar time to our house.
Further research discovered a company called Atkey who will make doors, architraves and skirting to the same design as the originals. Albeit at a price. But they do have a good website with lots of diagrams including this door from Bowood House. CD then chose architrave and skirting to suit.
Now I can’t post their pictures as they are copyright but you can see what we chose directly from their website
https://atkeyandco.com/product/georgian ... r-gdr0180/
https://atkeyandco.com/product/georgian ... g-gdm0180/
https://atkeyandco.com/product/georgian ... e-gar0195/
https://atkeyandco.com/product/georgian ... d-gsk0189/
So taking a cross-section of the moulding from their website, they state the overall dimensions, I make a simple four cell spreadsheet that will let me take the dimensions from the printout and convert them to actual size. I then rough sketch the drawings with dimensions thus.
Architrave - note two cutters required due to the size of the architrave
Door moulding - note two cutters required (scribe and profile) and a proper ovolo
Skirting
You can cross-reference these back to the profiles on the Atkey site.
At this point I like to send these drawings off to the supplier for a rough check that they are ‘doable’. The reason for this is that my original idea was to do the door profile and scribe in one pass with a groove in for the panel but I was told that they couldn’t machine up the small groove for the panel. So the door will now be a two pass moulding process.
If they’ve passed their sanity check then the next stage is for the supplier (I’m using Whitehill in this instance - other suppliers are available) to draw up proper drawings thus …
Door
All good.
Skirting - Rev 1
Note their comment at the bottom and referring the drawing to the Atkey profile it certainly looks wrong. Further inspection showed I’d cocked up on the initial drawing and the width of the skirting at this point is 22mm and not 28mm
Skirting - Rev 2
Spot on
Architrave - Rev 1
I wasn’t sure how this one would pan out because sometimes if the size and/or shape of the profile is such then you need a tilting spindle moulder (which I no longer have). But no tilt needed here. However, what I did pick up was that I could get the cutters altered to make the rebate as part of their profile and so cut down on the number of passes through the spindle moulder.
Architrave - Rev 2
Note that they missed out the requested change to the profile cutter on the left.
Architrave - Rev 3
All good.
And a few days later, the courier brought me these cutters. Chuffed to bits. Cost £60 a pair + VAT
Re: Making custom spindle moulder cutters
Postby Robert » 10 Dec 2018, 10:29
Interesting... but from the thread title I expected to see you with a lump of sheet metal and a bunch of files :)
Postby TrimTheKing » 10 Dec 2018, 10:44
Robert wrote:Interesting... but from the thread title I expected to see you with a lump of sheet metal and a bunch of files :)
Me too. Mildly disappointed. Shame on you Roger for leading us on!
Postby 9fingers » 10 Dec 2018, 11:03
I can see why you needed two cutters for the architrave with only a modest power spindle but I can't help feeling you might get a telltale line where they overlap.
Just possible that a piece of scrap "exactly" the right depth screwed to the fence will sort it out for the second pass but I reckon you will need to sort out your flexi-fence first.
Postby Malc2098 » 10 Dec 2018, 11:44
Fascinating to this here layman!
Postby 4ndy » 10 Dec 2018, 13:03
Really interesting to see, didn't realise such a service existed. Looking forward to see how these play out in practice.
It might not be broken, but it will be by the time I've finished with it! (hammer)
4ndy
Postby RogerS » 10 Dec 2018, 14:29
9fingers wrote:I can see why you needed two cutters for the architrave with only a modest power spindle but I can't help feeling you might get a telltale line where they overlap.
Quite possibly, Bob. Time will tell. Different fence...so no issues there :)
Postby Rod » 11 Dec 2018, 01:05
We’ve got the same style of doors, didn’t realise they were a Rbt Adams design.
Postby RogerS » 11 Dec 2018, 06:51
Rod wrote:We’ve got the same style of doors, didn’t realise they were a Rbt Adams design.
The key thing, Rod, is the relative dimensions of the stiles and rails. A six-panel door is nothing out of the ordinary but many modern doors (not saying that yours is) will have relatively narrow stiles and rails compared to a Georgian original. There is also the question as to the mouldings.
Georgian doors are also usually wider than their modern counterparts - a regret that I have for not biting the bullet and widening the door linings here when I had the chance.
