It is currently 29 Mar 2024, 07:26
RogerS wrote:No difference between the TRA001 and TRB001. Just denotes the country/market. The reference to a 2000w refers to a smaller Triton IIRC.
9fingers wrote:There used to be a Triton demonstrator on the forums ARGEE I think was his handle. He was very helpful to owners and prospective buyers. Even if he is not around now, you might find his posts in the UKW archives.
Andyp wrote:Terry,
No need to go under the table to switch on. Fit a switch to the front of the router table and slide the cover over the router's switch to leave it permanently "on".
Andyp wrote:Indeed but once the bit is fitted it can be locked on and controlled with a no volt switch on the front of the table as per mine.
RogerS wrote:Ray did use to have some destructions on taking a Triton apart but the link has gone. I do have a copy.
RogerS wrote:Ray is a top bloke. Shame he doesn't post much.
Newbie_Neil wrote:RogerS wrote:Ray did use to have some destructions on taking a Triton apart but the link has gone. I do have a copy.
Could you please let me have a copy?
Users browsing this forum: No registered users and 23 guests
