by kirkpoore1 » 13 Nov 2014, 05:15
That's possible too. A very thin board will sag coming off the the thicknesser. If it only has one hold down point (the outfeed roller, for example), the back end will raise up and into the cutterhead, giving you the snipe. It would be the reverse going into the machine, of course.
You may want to check your pressure bar. It's quite possible that it is set too high, allowing the same situation in some circumstances.
Kirk
