It is currently 29 Mar 2024, 14:46
by tracerman » 18 Jan 2015, 13:24
Folks , my 68 year old K3 series Multico mortiser has undergone some small refurbishments recently but there is something bugging me - the depth-stop on the right hand side consists of a bolt passed through a gap between the front face of the machine and a flat steel bar , there was a nut on the outside(right hand) end so I had to use a spanner every time I wanted to re-set the depth . There is now an M8 wingnut but I still need a spanner to ensure tightness . I find it hard to believe that this was the original set-up . If anyone has a picture of what was supposed to be there it would be appreciated . I can ( might) fit a small ball-end lever but I would first rather know what Multico fitted originally in 1947 .
Thanks
Steve .
tracerman
- Sapling
- Name: Steve
by DaveL » 18 Jan 2015, 15:24
I have no idea what was originally used, but would a Bristol lever solve your problem?
Regards,
DaveL
- Old Oak
- Name: Dave
by tracerman » 18 Jan 2015, 16:43
Davel , I had to look up to see what a Bristol Lever is .... and yes , one of those in steel and steel insert in M8 female would do the trick , but I am hoping to find out what Multico originally used . WDS have them but I'm tempted to go for a small ball-end lever as it would probably be kinder on my arthritic fingers .But thanks for the suggestion .
Steve
tracerman
- Sapling
- Name: Steve
