It is currently 29 Mar 2024, 10:24
RogerS wrote:The Axi 2200 is a good chip extractor. What did you do to replace the grotty top bag that they supply, Mark? I bought a sub-micron filter cartridge from RB Industrial...probably due for a replacement.
Wizard9999 wrote:Do you know if this is what is now branded as the AWEDE2?
Terry.
Wizard9999 wrote:OK, thanks chaps. Presume the Axi 2200 must be an loder model as can't see that in their website. Seems the closest spec is the FM3000BC.
2,000m³/hr @100mm inlet 2,500m³/hr @125mm inlet
150 litres
47kg
77dB(A)
1.5kW (230V, 1ph)
Hobby
Regards,
Terry.
stephen.wood125 wrote:...had I not got a great deal on the SIP at Costco then the big 2200 Axi would definitely have been on my watch list.
