I came across this article from HS&E about the safe use of emery on metalworking lathes and thought the advice might well apply to our craft?
http://www.hse.gov.uk/engineering/lathe ... /12-oct-15
It is currently 29 Mar 2024, 06:36
DaveL wrote:I do use loose abrasive, the rule is never wrap the abrasive round your fingers, hold it so if it catches, it is just pulled from your grip.
