Glad you all liked it it was good to get and do some turning for a change
Phil wrote:Derek, good looking bowl.
Nice blank full of character.
Like the chunky look.
What sort of sealer do you use?
Cellulose sander sealer applied while still on the lathe once that had dried I then buffed once it was completed
Andyp wrote:I do like it when a hole is left in the piece like that. I'd be worried about catching a tool in it though.
Can you share some details of your buffing system? Is this something you do on or off the lathe?
Because of the lathe speed the tool does not get the chance to go into the whole. When you do have a go take it gentle at first. After a while you get to know how bigger cut you can take it comes with practice.
